- Define the vendor option.
- Create the vendor class.
Perform this procedure to configure vendor option data for the specified vendor class.
The switch follows inheritance and precedence rules for configured DHCP Server options. For more information, see DHCP Server.
Configure vendor option data for a vendor class:
Switch:1>enable Switch:1#config t Switch:1(config)#ip dhcp-server vendor-class 20 vendor-option-data 2 value 1337 <cr>
The following table defines parameters for the ip dhcp-server vendor-class command.
Variable | Definition |
<1-255> |
Specifies the vendor class ID. |
vendor-option-data WORD<224-254> |
Specifies the DHCP code that identifies the vendor option. |
value WORD<0-128> |
Specifies a data value to apply to this vendor class. |
